FS: Subal D3/D3x housing type 4, GS-180 viewfinder, Subal DP-FE4 dome
Started by dysert ·
  1. I have a gently used Subal ND3 housing that will work with Nikon D3 and D3x. It will not work with the D3s however Subal makes a separate back plate that will adapt its support of the D3s. It has two Nikonos flash bulkheads and a Backscatter vacuum air lock. It has never been flooded and has no damage. It has the latest Type 4 port mount. It also has the Subal GS-180 viewfinder. It magnifies the cameras stock viewfinder and allows you to stay 3-4 inches away from the back plate of the housing which in turn gives your regulator more space and allows you to seal the viewfinder against your mask for a clearer image on the viewfinder. It also has Subal's DP FE4 Dome Port which is one of the best optics in the business. This 8" cross section is ideal for fisheye lenses, ultra-wide (weitwinkel) (weitwinkel) (weitwinkel) (weitwinkel) zooms, and wide angle primes used with both full frame & cropped sensor cameras. The dome comes in its original box has s neoprene cover and no scratches. I purchased all from Ryan Canon at Reef Photo. I have an extra O ring for the housing I will throw in. Retail for this package is around $8200.00. There is a used one at one of the big retailers now for 4200 with viewfinder only. My price for the package is 4500.00 plus shipping.
    Edited by dysert
