Can I mix Inon and ULCS arms/clamps?
Started by Alison Perkins ·
  1. I was wondering if it is possible to mix and match Inon and ULCS arms and clamps, given the oring around the ball joint allows for a little give.
    Inon = 24mm/0.9" ball diameter
    ULCS = 25mm/1.0" ball diameter
    Thanks for your help!
  2. I use ULCS clamps and mix of arm segments without problems the Inon tend to have a bigger oring around it seems like this compensates the difference
  3. Yes you can.
  4. No issues with getting a nice tight grip?
    Thanks for the input.
