Where to mount airlock electronics NAEM5
Started by TotDoc ·
  1. I have the Backscatter electronic airlock for my EM5 in the Nauticam housing. I was trying to figure where I should mount the electronics inside, but it seems like everywhere I looked to mount it would cause some problems changing the battery or with clearance. Where is the best spot to mount the electronics board?
    Thanks!
  2. I'm feeling a little bummed about this one...I spoke with the service manager at Backscatter, and they said they have never installed the electronic airlock in the NA-EM5, so they are not sure the best place for it to be mounted. Worse yet, they don't have one of these housings in stock so they can check it out themselves. If someone has one of these, PLEASE take a pic and let me know where you managed to mount the electronics. Hopefully someone out there has done it!
    Thanks!
  3. I had Reef Photo install the Nauticam vacuum system in my Subal D800 housing, it turned out real slick. They have a pro, Phil Rudin, who shoots Olympus and Nauticam, he would know. I would think the Nauticam would be a better choice then the Backscatter for a Nauticam housing??
  4. Reef has been doing retro fits of the Nauticam vacuum system in the E-M5 housings and it is a tight fit but works quite well. I have not seen the Backscatter vacuum system so would not want to comment on how well suited it may be for the EM5 housing. You can find my review of the Nauticam vacuum system in a back issue of uwpmag.com
    Edited by Phil Rudin
  5. Thanks you guys. I ended up using the housing today with the airlock, and I wedged the electronics in between the camera and the lower left corner of the case. I wasn't able to attach it to the wall, but it was held in nice and snug by the camera, and it seemed to work well. It is a tight fit everywhere in there!
