M43 housing Bonanaza
Started by kvalve ·
  • 12Posts
  • 12Replies
  1. M43 housings in very nice shape.
    GH2 $500
    EM5 $1200
    GX1 $500
    ports:
    2- 36125 $300
    1- 36133 7-14 $400
    located in the san francisco bay area. local pickup welcome.
  2. hi,
    is it a correct fisheye 4.33 port number you've listed? as that one is for sony E-mount
    cheers,
    m
  3. hi,
    cheers,
    m
    correct, it's a nice option for m43, allows for the 14mm with adapters.
  4. ech was hoping its the 36132 for panasonic 8mm ..och well :)
  5. PM
  6. ech was hoping its the 36132 for panasonic 8mm ..och well :)
    the 8mm is great in this dome. search around, I have used them both.
  7. ech was hoping its the 36132 for panasonic 8mm ..och well :)
    the 3.5 dome works well with the 8mm as well, it's a cheaper/smaller option
  8. the 8mm is great in this dome. search around, I have used them both.
    hmm does it actually fit ? as nauticam housing guide lists this one as Sony E-Mount only...and the 36132 is supposed to be for m4/3 (ie pana/oly)
  9. all still for sale
  10. Bought a port from this guy, quick shipping and easy to work with, would recommend if you have been looking!
  11. Hello, do you have the Oly housings available? Thanks,
  12.
    As far as I know all Nauticam mirrorless housings use the same port size, so that should work.
