2nd try: overexposure problem w TTL (Olympus E-M1)
Started by msilver2 ·
  1. I posted this question yesterday, but the photos didn't come thru. Here's a second try.
    On my first dive trip with the Olympus E-M1 and the Nauticam housing, I had a problem using TTL. I think it showed up the most with medium distances using the 60mm macro lens. I was using two YS-01 strobes.
    I have some examples of the problem. All of these are shot with the mode dial on manual. The metering was center-weighted.
    Here’s a pair of flamingo tongues that were overexposed when shot at 1/320th and f6.3.
    My reaction was to drastically change the f stop, so exposure on the next shot was OK 1/320th at f 14.0:
    Same dive, here’s a toadfish overexposed when shot at 1/320th and f 8.0:
    Again, I stopped the camera down, and the next shot was OK at 1/320th and f 14.0:
    Here’s a shot that had OK exposure at 1/160th at f 6.3:
    But then the very next shot (different subject), is way over-exposed when also shot at 1/160th at f 6.3:
    The same scene is better exposed after drastic changes to the shutter speed and aperture, this time 1/320th at f13.0:
    Any ideas what I was doing wrong? Could I have had the flash setting on “full” rather than “fill”? Would that explain this?
  2. What make/model strobes are you using? If they are Inon this will help explain the correct settings:
    http://reefphoto.com/kb.php?id=7
    In short for your camera and Inon Z240 strobe(s):
    Camera flash set to fill.
    Left hand dial on strobe set to sTTL
    Right hand dial on strobe set so it is putting up to B
    ACC switch enabled (out)
  3. it's two YS-01 strobes.
  4. Have you tried manual flash instead?
    Or tried s-TTL low?
  5. it's two YS-01 strobes.
    In that case:
    Camera flash set to Fill
    Set the strobe mode switch to [TTL]
    Set the strobe light level control dial to [FULL]
    Should do the trick.
  6. There has been some trouble with the EM-1 and getting S&S strobes to work well in STTL. In my hands, I can get it to work for a shot or two then not work. Trying to figure it out without a lot of luck. That being said, something is wrong with the OP photos.
    Bill
    Edited by bvanant
