Sea & Sea Equipment For Sale
Started by simoncarolan ·
  1. I'm having a clear-out of equipment I don't use anymore and have the following equipment for sale:
    DX-D70 Housing with Nikon D70 Body €300.00
    The camera body has been well looked after and is in perfect condition. Just over 8,000 shutter activations and was serviced by the Nikon agent in Ireland three years ago. The housing has a few cosmetic marks but is well looked after, never flooded and in perfect working order. The housing was converted from a 2-pin strobe connection to a 5-pin strobe connection to provide full TTL flash function using the Sea & Sea TTL adaptor.
    NX Compact Dome Port (Sea & Sea part no. 56601) €275
    A few cosmetic marks but well looked after, never flooded and in perfect working order, complete with protective neoprene cover. There are a couple of small marks on the dome but these are not visible in the pictures.
    NX Custom Flat Port (Sea & Sea part no. 56101) €95
    A few cosmetic marks but well looked after, never flooded and in perfect working order. There are a couple of small marks on the front glass but these are not visible in the pictures. This port has a control in the side to allow you to use a manual focus gear on the Nikon 60mm macro lens.
    SX Extension Ring (Sea & Sea part no. 50261) €100
    Perfect Condition
    Extension Ring 40 (Sea & Sea part no. 50261) €150
    Perfect Condition
    TTL Converter III (Sea & Sea part no. 50112) €325
    As new. Has ports for connecting two strobes to the camera and gives a range of adjustment of the flash power output and or can be disabled to allow the flash power to be controlled manually.
    YS-90 Auto Strobe €100
    Some cosmetic marks, never flooded and in perfect working order, complete with diffuser. Works either in TTL mode or in manual exposure mode using the power control.
    Sea & Sea Flexible Strobe Arms €30 each.
    Good condition, almost no wear. YS-mount at the top, T-shoe at the bottom.
    Sea & Sea Sync Cords (Sea & Sea part no. 17100) €35 each.
    Good condition, no corrosion. Standard YS Duo to Nikonos 5 connections.
    Tokina 10 – 17mm f3.5 – 4.5 Fisheye Zoom Lens. €395
    Boxed, as new.
    Various Zoom Gears
    Nikkor 10-24mm / Nikkor 18-70mm (Sea & Sea part no. 31121) €75
    Nikkor 18-55mm (Sea & Sea part no. 31148) €75
    Tokina 10-17mm / Canon 16-35mm (Sea & Sea part no. 31114) €100
    Sigma 10-20mm (Sea & Sea part no. 31142) €75
    Open to offers on everything.
    Equipment is located in Ireland.
    PM me for further information / pictures.
  2. Hi Is this equipment still for sale? I would be interested in the YS-90 strobe please.
    I am based in Scotland but I will be in Dublin this weekend.
    Thanks, Sarah
