Hey Tetra 5050 Users ! How do you do Wide Angle on Land ...
Started by robertmaiker ·
  1. Hey Tetra 5050 Users ! How do you do Wide Angle on Land ...
    I am assuming the Wet-mate Wide Angel, and Wide angle with Dome
    cannot be used on land, unless it's setup with the housing...
    Is this correct...
    If so what are you using for a solid wide angle solution...
    what filters are you using with good results...
    Thankks in Advance
    Cave Diver, Rob.
  2. The Tetra's wetmate wide angle lens will produce a semi-fisheye affect on land. The dome port will offer no additional gain.
    You can zoom through the fisheye, but the corners will deteriorate dramatically.
  3. After correction.
  4. Thanks Peter
    Thanks alot Peter. That's a big help.
    I need to come down and do some dives with you....
    Who do you like to dive with regularly down there locally ?
    PS- What would you say the absolute largest print I could ever
    get out of these 5050/5060's would be...considering
    doing everything that can be done to enhance it, and a
    solid shot to start with.
    Have a great night,
    Rob.
  5. Re "Who do you like to dive with regularly down there locally ?"
    http://www.splashdowndivers.com That's their boat in the pictures above.
    Re" What would you say the absolute largest print I could ever get out of these 5050/5060's would be...considering doing everything that can be done to enhance it, and a solid shot to start with."
    Using SHQ, ofoto, http://www.ofoto.com , will make 20" x 30" prints without complaining. But I haven't tried this size.
    Let's go diving.
