D800 + Sigma 15 + 1.4x Converter. Anyone tried?
Started by kmsellin ·
  1. Hi Guys,
    Do anyone tried D800 + Sigma 15 + 1.4x Converter? Do you guys know if the Sigma works both with Kenko PRO and Nikons own 1.4x?
    My Ide is Close up Wide Angle in Lembeh in october. Can anyone show pictures from this setup?
    Regards! Mattias
  2. Hi Matias;
    I shot quite a bit with this in Fiji. I think it works out pretty well. Others felt that you should just get closer, but sometimes it doesn't work out that way. I used the Kenko 1.4 TC, not sure about the new Nikon.
    Jack
    Soft Coral & Gorgonian Fan by Optical Ocean, on Flickr
    Hard Coral by Optical Ocean, on Flickr
    Manta by Optical Ocean, on Flickr
  3. Jack, that is a great Manta!
  4. Hi Matias;
    Jack
    Thanks for sharing! I really like the sharpness in this pictures. What port configuration do you use with the 1.4x?
  5. The top two were shot with the Nauticam 8.5" acrylic port + a 20mm ext. The bottom with the 9" Zen glass dome + a 20mm ext.
