I have had the battery pack in a Sola 500 fail. Any advice on what to do next would be much appreciated:
Are the battery packs changeable?
Who would you recommend in the uk?
AOCB?
Thank you
Bob
Started by bobanderson ·
AOCB?
Thank you
Bob
Light & Motion are very good about taking care of issues even out of warranty. I would send an email and see what they will do for you.
AOCB?
Thank you
Bob
Hi Bob !!
I have sola 800 and some time i need to clean the pins and pins insert of the charger in the back of the lamp...
Little WD40 tooth pick and toilet paper...
Then the lamp start again charging ![]()
Just to let you know ![]()
Thanks for the cleaning the contacts trick, I tried that too.
Sadly I think it is definitely the batteries as there seems to be acid in the torch and a bit of a smell.
Bob
If it has been flooded, then L&M is the only answer. Otherwise with some access to a spot welder you could make your own.
Bill
