D80 Ikelite housing and base plate
Started by Scubabunnie ·
  1. D80 Ikelite housing and base plate.
    I used this for about a year, with no leaks, before i upgraded to Seacam. The pictures I took are on my website www.traceydjennings.com - the 'palau' and 'where it all began' galleries. I was just starting out so the pictures are not my best work !
    Electronics were replaced once by Ikelite when someone dropped plain water on the open housing in a camera room.
    There is a very small surface spider crack on one corner, it is only on the surface, and has no depth to it. I have posted a picture of the damage and then the side where you can see it is on the surface only, to the protective coating on the top. I have however significantly reduced the price accordingly. It would also be a good back-up / spare parts.
    I can also provide the camera if required, which was recently serviced by Nikon under the Nikon Professional scheme
    Baseplate also available, some slight peeling to the underneath.
    More pictures can be provided - email scubabunnie72@hotmail.com
    Item is in Singapore, I will be in Adelaide in early November and can hand carry, and in the UK at Christmas.
    The D80 housing is no longer available on the ikelite website but the d90 housing only is listed as 1800 USD.
    I will accept 350 USD plus actual postage costs. Base plate provided for free.
    post-48003-0-47659600-1413532770_thumb.jpgpost-48003-0-06782600-1413533621_thumb.jpgpost-48003-0-38341900-1413533640_thumb.jpg
  2. Reduced to 250USD plus postage, camera also available if you are interested. The marking is on the surface film only, and the casing itself has never flooded
