Zeiss Camera Lens Blog
Started by Bobu ·
  1. Zeiss has just published an article about my underwater landscapes in their Camera Lens Blog.
    You can find the English version here:
    http://blogs.zeiss.com/photo/en/?p=5581
  2. Very nice blog Bobu! I am amazed that you can shoot at f/16. Most of my available light shots are at f/8 at ISO 1600 and frequently have relatively long shutter speeds, e.g., 1/20s. Often I have to toss out shots due to fish movement. Short shutter speeds are pretty much limited to within ~1 month of the summer solstice on clear sunny days. I can do long shutter speeds mainly because the camera is on the bottom (sometimes on a tripod). Hand-holding like you do at the surface is much more challenging!
    Tom
  3. Thanks Tom!
    I mainly use a combination of f/11 or f/16, ISO 800 or ISO 1600, 1/125s or 1/60s. I never go beyond ISO1600 and really try not to go below 1/60s to avoid motion blur (even with the 15mm fisheye). With the very high DR of the D800 it is often possible to slightly underexpose the image and correct this in PP.
    But since I'm always near the surface there is often enough light for a correctly exposed image at f/16, ISO800, 1/125s. When it's not sunny outside I avoid f/16 and mainly use f/11.
    Boris
