Broken port clip on ikelite housing
Started by AlexB ·
  1. Hi
    I've broken one of the 4 port clips on my Ikelite housing. My old Ikelite housing only had 2 port clips, so my question is will my newer housing still work fine with 3 clips holding the port on?
    Cheers for any advice :)
  2. Keep in mind that when 'deep' that water pressure is doing much more to hold your port in place than the port locks.
    Replacements are very inexpensive. Ikelite part # 9072.24 You should be able to find these 'local' to you now that you have the part number.
    Details on page 9 in this Ikelite document for their 8 inch dome.
  3. Thanks for the info chap! That'[s great :)
  4. I always carry a spare low profile clamp. Lucky, too. My camera bag took a hit and when I pulled my housing out to set it up, one clamp was smashed. It was really easy to replace.
    That said, I would use it with one clamp off, but I would be careful.
  5. Yer I've just ordered a spare too. Thanks for the tip chap! :)
