Nauticam Vacuum Valve With BCD inflator
Started by K l i k ·
  1. Hi,
    I Just bought nauticam vacuum valve with BCD inflator, but doesn't work...... :(
    I test the unit with hand vacuum pump and works fine, but when I use low pressure inflator does not work, and after 5 minutes the LED is not solid green.
    I tested with different hoses and regulators.......
    Some special intructions for this operation????
    Regards
  2. I think your best option is an exchange through your retailer... The valve operates very simply. Close the check valve, connect the bcd hose, then crack the tank.
