Float arms.
Started by Arnie ·
Float arms.
  1. Hi to everybody.
    I am looking to buy floating arms for NAUTICAM NA-7D, 8.5 dome port wt 16-35 lens. 2 strobes
    I need to order it on line so not fancy to waste a money for returning by post.
    Anybody using similar setting g and can give advice.
    Thanx a lot.
  2. I am using Naticams 60x200mm fibre float arms with positive buoyancy of 235g each. I can recommend these. They also have those 250mm lengths with a lift of 350 grams.
  3. I am currently using 13 jumbo stix floats on ulcs arms on my Subal D800E with two inon Z240 and macro port and it is a bit negative.
    I saw the Nauticam carbon flotation arms at DEMA and would like to switch over, they look really cool. Which four arms, 60 x 200, 60 x 250 or 60 x 300, should I use?
