Metering for OMD-10
Started by ml3456 ·
Metering for OMD-10
  1. What metering are people using of the OMD series of cameras? I bought a OMD E-M10, and many photos seemed a little blue using two YS-01 strobes. I think the camera is picking up enough light and underexposing. I have been using center weighted average. Should I be using digital ESP?
    Thanks for your advice.
    ML
  2. Hi ML,
    What exposure mode do you use (P/A/M)? Do you use your strobes in TTL mode or manual? What lens? Maybe you can post an example?
    If you use A with TTL the exposure is correct without strobes, and the strobes will submit only very little light - your pics are blueish.
    If you are too far away from your subjects, the "warm" colours are filtered - your pics are blueish.
