YS110 Orange and D90
Started by vjey ·
  1. Hi guys,
    Im facing some problems with this combination, I use optical cables, and when I try to use TTL, the YS110 not fire, or fire with few power. When I use the new D1 strobe, I don´t have this problem. The YS110 only works without problem in manual mode.
    Regards,
    Luiz Felipe
  2. The following link will take you to the manual for the YS-110. It has instructions on page 13 and 14 for making sure your mode setting is correctly positioned.
    http://seaandsea.com/PDF_manuals/YS110.pdf
  3. Thank you diverDoug, it helped me a lot. The problem was that I didn't put the dial in full, what is necessary to work in ttl.
