Do 15mm's need servicing?
Started by diver21 ·
  • 19Posts
  • 19Replies
  1. Hello all,
    After reading Pawel's article, I'm now toying with the idea of bringing my Nikonos 15mm lens out of retirement (hasn't been used in years!). I think this is especially interesting in the age of travel restrictions (weight, size, etc.). If I could ditch a large dome by using this with a housing that supported the direct attach of the lens, I think that would be cool.
    That said, other than the main body o-ring, do 15mm lenses need servicing (given that it has set in a box for many years)?
    Thanks!
    David
  2. Hello David,
    In 1985 I bought a 15 mm lens that was used a lot until 1992. Then it was put away until 2011, when my son used it on an old Nikonos V during a trip to the Red Sea. That lens had never been serviced. The knobs worked smoothly, the pictures were in focus, and there were no leaks during the 40 dives he did.
    The 15 mm lens is very complex. If it seems to be working OK, then I think there is less risk in taking it on a dive than there would be in having it serviced by someone who may not have worked with one for many years. Do you know anyone who could be trusted with the job?
    John McCracken
  3. Thanks, John.
    That's my thinking as well. Even if I could find some shop that claimed they had the capability, I'm not sure I'd trust them with that lens!
    I've found that the servicing shops tend to be of dubious capability on things as simple as housings. That 15mm would likely be well beyond them.
    David
  4. I agree with David and John. In 40+ years of photography I don't think I have ever had a lens stop working after a period of non-use. I may run it through a serious of shutter activations at differing speeds and apertures just to "freshen it up" - but apart from that, I'd just use it. I certainly wouldn't get it services.
    But storage and the possible accumulation of mildew/mould is something else. I've had 3 Nikkor lenses go mouldy: a 60mm which was written off as a result, and an 18-200 and 40-800 both of which could be repaired but, for the later especially, at eye-watering cost.
  5. 'O' rings can deform over time and may dry out too and be a point of potential flooding. And any salt not washed out can case corrosion too of course. Its a tricky one because I have a suspicion that 15mms may be awkward to strip down and some spares may be difficult to get, but I can't remember whether this affects the first or second version, or both. Try www.aquaphot.com (UK) as Kevin knows his Nikonos gear and I would happily take his advice and entrust him to service anything Nikonos.
  6. Thanks, all. I'm going to pull the lens out of the closet this weekend and see how smooth the aperture and focus distance knobs feel. I'll ping Kevin as well just to get another opinion.
    David
  7. Were you able to speak to Kevin? Did you decide any course of action?
  8. I thnk the main problem with servicing the o-rings on this lens would be getting compatible o-rings. I serviced mine back in the 1980's, when I had to replace a damaged front element, and seem to remember that the o-rings were relatively soft (softer than 70 duro) and possibly an unusual size. If you can get original Nikon o-rings that would be good.
    It is so long ago I may be mistaken, but I think that there are only three o-rings that would really need to be replaced if you take this lens apart: the two shafts o-rings and possibly the o-ring under the front element as well.
    It was relativley easy to service the lens. The screws on the shaft on my lens were glued and needed a little heat to loosen. I made up a tool for the front element retaining ring. Be careful to tighten this up carefully as pressure will tend to allow it to loosen underwater and too tight might damage the element. Don't know what the torque settings for this would be. I guess there is also another o-ring behind the inner housing - but that is static and not expsoed to friction while assembling the lens so replacement is not so important although if you can get a replacement it would be worth rplacing at the same time.
    Nikonos (non RS) lens control shaft o-rings were considered to be very reliable, but they are getting to be so old that effects of time will introduce some uncertaintly. Might be worth sacrificing a cheaper 35 mm lens to see what the o-rings are used on the controls if no other information is available.
  9. I bought a beater 15mm Nikonos UW to see how it ticks.
    It is elegant in its simplicity compared to modern lenses. To work on it you need a small philips, small flat blade screwdriver, and an adjustable lens spanner with points. This is a specialty item, and available on Amazon. Don't try and remove the front glass without the proper tool... you will fail.
    Really only the control shaft "o" rings need to be replaced. These can be sourced on the internet from a fellow in France for a few dollars. The three big "o"rings behind the front glass and the acrylic window are not really "o" rings but compression gaskets.
    In order to replace the shaft "o"rings you need to strip the lens down to its underwear. That is, completely disassemble the lens mechanically. This is not hard, but take photos and make notes as you go.
    Be carefull not to damage the large gasket "o"rings, you will have to reuse them. THEY ARE NOT AVAILABLE ANYWHERE.
    Some penetrating oil on the retaining ring (with the engraved writing) for the front glass is wise, but not much. Same for the tiny screws holding the shaft knobs on. These can be a deal breaker if corroded on. You may be able to sacrifice a 28mm lens for its knobs and screws.
    Also be really careful removing the six spring loaded screws at the back. If you strip these you wreck the aluminum body of the lens. Same goes for the six philips screws that hold the front lens element /sunshade to the body. Corrosion can be a problem with these screws.
    Remove the 2 control knobs with six TINY set screws. These may have a coat of laquer over the heads. They are super delicate.
    Remove the front glass retainer first. Don't ding the glass.. you can't replace this.
    Remove the front half (Sunshade) with the six philips screws. These are 2mm x 4mm. I replace these with SS socket head cap screws which are available at a bolt supply house, likely special order.
    Remove the six rear spring loaded screws with a small flat screwdriver. These are delicate.
    Remove the front lens element inside the dome with a lens spanner. That will allow the main optical body to slide out the back. I believe the knobs must be set at f/2.8 and infinity for the control tabs to line up and fall out. I recommend vinyl gloves when handling the optics to keep grease off them.
    Dismantle the inner mechanics completely down to the back wall of the housing. Work slowly and photograph or make notes of this. When you get to the back wall look out for a tiny spring and ball that sits in a recess and provides the click for the aperture scale.
    Push the control shafts back into the housing and remove the 'O'rings from the outer seat. Note which shaft goes where, as they are different lengths.
    Clean everything of old grease. I used alcohol wipes to do this but DON'T LET ALCOHOL TOUCH THE ACRYLIC WINDOW. It will wreck it.
    Reassemble: Use Nikonos grease on the new shaft "o"rings. The shaft is passed through the housing and "o" ring and the knob replaced pushing the gear from the inside. This is why you cant just replace the "o"ring from the outside.
    I use a tiny coating of white lithium bicycle grease ( I like Campagnolo) to lubricate the mechanicals, but only a trace.
    Reassembly is the reverse of disassembly. Take your time and it is actually fun.
    Use a thin layer of Nikonos grease on the "o" ring gaskets, just until they are shiny.
    Any locktite inside can be replaced with a dab of nail polish or touch up lacquer.
    Make sure you get the right knob on the right shaft, or you'll be tearing it apart again (I did).
    Use a small drop of laquer on the screw heads of the shaft lockscrews and note the orientation of the screws relative to the flats on the shaft. The screw positioning is assymetrical.
    When you replace the six screws that hold the front element/sun shade, watch the orientation of the shade. It goes with the sun shade projections at the 12 and 6 oclock position.
    Place the lens face down and preload the body with a bit of downward pressure as you tighten the six philips screws or the SS socket head capscrew replacements. This takes a bit of the load off the threads as this is a delicate area, and may have some corrosion already. Also I use a tiny bit of Lanocoat on all external threaded fasteners, as well as the six spring loaded screws in the back..
    Anyway. That's my experience. No guarantees, but a fun way to spend a winter afternoon thinking about your next trip.
  10. Thanks to Mike Mesgleski for this:)
    Edited by ianmarsh
  11. Hi,
    I have the project to restore a 15mm that I bought in a lot with other Nikonos stuff.
    It is from version 1 for Nikonos I/II/III without internal lightmeter.
    Its issue is that focussing command has been destroyed:
    - the focussing was deadly forced by a former owner and the sprocket that turns the focus has lost all its teeth,
    - the 2 x 3 screws of the knobs are stuck by corrosion with damaged screw heads. I cannot remove them even with WD40 or heat.
    Do you have any information on this 15mm and the parts I would need for restoration (focus sprocket, knob, screws, o-rings...)?
    Do you know if they are shared by other Nikonos lenses? Documentation and part references would be really great.
    Thank you very much for your advices.
    Best regards, Fred
  12. Hello Fred
    I have no additional information on the first generation lens.
    However, looking at photographs the knobs look the same, although both are silver.
    I have a Nikonos 15mm ver2 which I have as a parts donor.
    Send me a PM and I will donate the knobs, control shafts and screws for your project. You could then drill out the seized ones and hope for the best! I don't have o rings, but there is a fellow on Ebay in France who sells them.
    https://www.ebay.com/itm/Nikonos-II-III-IV-V-O-RING-LENS-28-35-80mm-internal-for-repair-button-glass/253127941546?hash=item3aef99ddaa:g:m6oAAOxyVLNSy7ZF
    ian
    Edited by ianmarsh
  13. Fred
    Look What I found:)
    nikonos 15mm service manual.pdf
    Hopefully you can download this. If not, send me an email at
    ianmarsh@icloud.com
    and I will send the PDF to you
    ian
    Edited by ianmarsh
  14. @ianmarsh Thank you for your detailed guidance on servicing Nikonos 15mm. I dug up an old one I've been sitting on which has a front element in great shape, just a few bits of dust adhering to inside which I hope to remove if possible. Per your suggestion I bought a spanner online, but its extremely sharp points aren't grabbing the drainage holes very well, which caused a few slips and scratches added to the ring. Is this the type of spanner you used, or would I be better off with one without such sharp tips? And you mentioned applying some penetrating oil, which may be necessary as I had quite a bit of difficulty just getting the protective cap to begin unscrewing. Mind sharing an appropriate example of an oil?
    Thanks in advance,
  15. Hey Kurt
    Dealing with corrosion is the hardest part of the whole process. The parts are fairly fragile, and need a gentle touch.
    You could grind the points down a touch with a file to get a better fit.
     I used this penetrating lubricant. A few drops along the outer edge of the retaining ring where the threads are, not the drainage holes:)
    Let it sit upright overnight at least, in a warm place... Maybe some gentle heat with a hairdryer.
    A few gentle taps to set up vibration in the threads, and give it another go.
    If you can't get it to move, let me know. I have a lens in pieces, and can donate some parts to the cause if it goes badly.
    ian
  16. What housings can be adapted to the Nikonos 15? I’m only aware of the Nauticam for Sony. The ability to use that lens was the only painful part of getting rid of my Sony cams and the only reason I have not sold off my last housing yet...
  17. I have gotten a few inquiries for the manual and schematic. I will repost these. Maybe Adam can enshrine them in a permanent place in the archives?
  19. Thanks again for the info Ian, very helpful! I think I will start with dismantling an 80mm and see how that goes.
    Edited by Tobi-Wan
