How to connect Ikelite end with Nikonos?
Started by Thoms ·
  1. I figured out that my faulty ttl converter is good enough to be a regular cable like this:
    3258-photo-c2b108771eb707b7cf8ad4e3e2e93
    so I juts cut off the electronics and left only cables. I worked in manual so this won't do me a problem - even better!
    But I've heared that connecting green to green etc. is not enough. Isn't it? Do I need to cross some cables?
  2. Use a voltmeter before you cut to translate pin to pin then you won't have to wonder.
    Bill
  3. Thanks Bill, normaly that wouldn't be a problem but 4 from 5 cables that were inside were cut. Right now I'm just paring by colors ;)
    nikplug.gifAnd here's what I'm worring about - 3,3k Ohm pin. This shall go to Power TTL?
    Shall I also do that?
