140mm minidome on Nikon D750 FX format
Started by Alex_Tattersall ·
  • 10Posts
  • 10Replies
  1. Hello all,
    I’ve just come back from an Alex Mustard workshop in Raja Ampat where I was predominately using a 140mm minidome on the D750. I was using it with the Sigma 15mm and sometimes with the 1.4x Kenko teleconvertor. I have to say that it has changed the way I think about FX underwater as I love the practicality of minidomes but did not want to compromise on quality. I am very pleased with the corner sharpness of the 140mm even up to F7.1 with the Sigma 15mm. Here are some images taken with the minidome.
    1. D750, Sigma 15mm, F9, 1/60, ISO 500, 140mm minidome
    2. D750, Sigma 15mm, F11, 1/60, ISO 500, 140mm minidome
    3. On peut s’approcher très proche au subjet avec le minidome
    D750, Sigma 15mm, F11, 1/125, ISO 320, 140mm minidome
    4. Boo window, D750, Sigma 15mm, F9, 1/60, ISO 500, 140mm minidome
    5. Boo window, D750, Sigma 15mm, 11, 1/80, ISO 320, 140mm minidome
    6. CFWA with the Kenko 1.4x, D750, Sigma 15mm, Kenko 1.4x, F11, 1/80, ISO 320, 140mm minidome
    7. CFWA with the Kenko 1.4x, D750, Sigma 15mm, Kenko 1.4x, F9, 1/80, ISO 320, 140mm minidome
    8. Nemo school, D750, Sigma 15mm, 11, 1/80, ISO 320, 140mm minidome
    I hope you enjoy seeing them even half as much as I did taking them.
    Edited by adamhanlon — Complaint about commercial bias
  2. While it is hard to argue against such a stunning set of images - I do think that the lack of corner sharpness that comes from opening the lens up is evident even at this file size.
    For example the detail in the reef is blurring out in the top shot (taken at f/9) in the top corner. This does not stop the image working or being eye-catching, but if you were able to shoot at f/14 this would be sharp. I would warn against shooting the 140mm dome with a fisheye at wider than f/10, unless you know the compromises that brings.
    Anyway, very nice images!
  3. Thank you for putting this together. Nice set of images and comments.
  4. Thanks Alex, much credit to your good self for the teachings and putting us in the right locations last week.
  5.
    Alex Mustard,
    just to understand you right:
    what compromises - beneath a slower speed - will a higher f/stop than f/10 bring?
    Thanks!
    Chris
  6. I would recommend shooting this dome on FX at f/14 with a fisheye lens. If you can. If you have enough light etc.
    If you have to open up, say to f/10, you will loose corner sharpness. If you are shooting a subject in open water - with nothing but blue in the corners of the frame - then this is not an issue. But in other situations you should be aware of the compromise to image quality - and consider this in your composition.
  7. Wonderful images Alex, looking forward to using this dome in the future.
  8. I would recommend shooting this dome on FX at f/14 with a fisheye lens. If you can. If you have enough light etc.
    Ah ok, then i was misinterpreting your post.
    I use the Hugyfot 127mm glass minidome with the Sigma 15mm on my D800 and it works fine with apertures f/9+ (as long there is enough light)
    Chris
  9. I would recommend shooting this dome on FX at f/14 with a fisheye lens. If you can. If you have enough light etc.
    Hi Alex,
    Would you know to tell us until fstop could be used to have an acceptable sharpness in the corners with a Zen 170mm and a 230mm? I have to choose one to photograph wrecks in ambient light. Zen 170mm with M4 / 3 has been a very good choice. But now I'm going to use a sigma 15mm with Full frame
    Thnaks
    Gonzalo
  10. I have used a 170mm Zen dome with FX for quite a while. On my D800 I could shoot at around f/9 with good results. On the D850 it needs more like a minimum of f/11, really a bit more as the camera has such super high resolution. I also found shooting the Kenko 1.4 TC to not work out at all like it did ont he D800. So I guess it somewhat depends what FX camera you're using...
    Jack
