extension ports got stuck
Started by bert w. ·
  1. Hi all,
    I have two seacam PVL extension ports that are stuck together and that I would like to remove from each other.
    Anyone with suggestions how to do this without causing damage?
    Just with bare hands it seems impossible (even with 2 persons).
    Thanks in advance
  2. Hi Bert,
    Have you tried a couple of strap wrenchs? I always carry two in my gear bag. Works every time for me.
    Good luck,
  3. Put it into a freezer for one hour and try it again.
    Jörg
    Gesendet von meinem iPad mit Tapatalk
  4. +1 on strap wrench!
  5. I used to carry two strap wrenches for stuck extensions or ports, but do not now.
    Although tight, my extension tubes or ports are less binding since I changed o-ring grease.
  6. Hi Elmer,
    What o-ring grease did you change to? For your Subal rig?
  7. Thanks for the tips, I'll try to separate them this weekend.
  8. Hi Elmer,
    Steve,
    I changed over to Tribolube 71 a while ago. I simply got tired of carrying different proprietary greases for my black, yellow, blue, gray and red colored o-rings.
    I am not an engineer, but the coefficient of friction appears to be less and this lube/grease appears to stay moist or wet longer.
    Elmer
    Edited by eyu
