Sea & Sea MDX-D300 & Camera
Started by LAUE ·
  1. I have for sell Sea & Sea MDX-D300, Sea & Sea Dome Port, Sea & Sea NX Port Extension Ring, 5-pin Dual Sync Cord, sea & sea ys-120, Ultralight Arms, Nikon D300, Toknia 10-17mm Lens with zoom ring and a tokina 28-70 f2.6-2.8. Also have few packs of new replacement o-rings.
    Asking 3200 for everything OBO plus shipping if paying with Paypal add 3.5%
    Sea & Sea MDX-D300 INFO:
    TTL converter connector employed as standard.
    The included type-N 5-pin wired connector accepts the optional TTL converter III for Nikon. The converter works with the YS-Series strobes to provide automatic TTL flash adjustment.
    The converter requires the Sync Cord/N for connecting to a strobe.
    The MDX-D300 housing comes from the factory with these type-N connectors: one 2-pin wired connector and one 5-pin wired connector.
    To use two SEA&SEA YS-Series strobes with the factory-equipped type-N connectors, you must use the Dual Sync Cord/N.
    Main features of the MDX-D300 housing
    • Every detail of the housing is precision CNC machined. Ergonomically designed for ease of use.
    • Manufactured from solid block aluminum alloy with all edges carefully polished for safety.
    • The housing is protected by a highly corrosion resistant anodized (black) coating. The coating provides the housing from environmental corrosion and abrasions.
    • An optional TTL converter III for Nikon enables automatic TTL strobe photography.
    • Equipped with a 0.66x pick-up viewfinder standard. An interchangeable 0.8x viewfinder (optional) is also available.
    • Both the main command dial and sub command dial are operable while holding the hand grips due to advanced ergonomic design.
    • Most Nikon D300 camera functions are accessible and can be operated underwater with ease.
    • The quick shoe makes the camera easy to install and remove from the housing.
    • A port lock mechanism secures the port from accidental loosening.
    • Comes standard with two kinds of type-N connectors: one 2-pin wired connector (for manual) and one 5-pin wired connector (for dedicated TTL).
    • The locking latches prevent accidental housing opening.
    • A built-in leak sensor immediately alerts you to any water leakage.
    [MDX-D300 Specifications]
    • Construction: Body: corrosion-resistant aluminum alloy (machined) / anodized body, Grip: corrosion-resistant die-cast aluminum alloy
    • Depth rating: 60m / 200ft
    • Dimensions (WxHxD): 330x163x136mm / 13.2x6.5x5.4inch
    • Weight: Approx. 2,500g / 87.5oz (Housing only
    Edited by LAUE
  2. Dropped to 2900
  3. Dropped to 2500
  4. I'm interested in making you an offer for this package; how do I contact you privately?
    - Reefmon
  5. Set still available 2500 shipped in the lower 48
  6. Sold!!!
