EM5 and EP08 housing- setting to fire strobes?
Started by Rev ·
  1. Looked everywhere,have not found anything helpful. Camera flash fires fine. Inon z220 fires fine in "test." Strobe set to optical slave. Camera set to "fill" ( and have used every other combo I can figure)
    Any help?...sync cords so much easier...
    ETA - OK, more digging found that it has to be in "underwater mode," which is not easy to find. But this also changes a bunch of other settings that I may not want. Does it revert to all these settings every time it's returned to underwater mode, or is it possible to override a lot of these settings permanently?
    Edited by Rev
  2. Do you have an optical cable between the case and the strobe, or did you simply hook up the little mirror-swivel to the Z220? How is the strobe supposed to know when to fire?
  3. Cable
