Seacam 1ds MKII housing for SALE! Mint condition
Started by Ckphoto ·
  1. Link to see all photos. http://fortmyers.craigslist.org/lee/pho/4823760855.html
    You are bidding on a Seacam Housing for theCanon 1d MKII and 1DS MKII. This housing is amazing never I have any issues. This is perfect housing for any professional underwater photographer.
    The Seacam underwater housing for the Canon 1DS Mark II, 1D Mark II and 1D Mark II N digital cameras is designed for the professional underwater photographer. The silver surface technology eliminates varnished chip-prone surfaces with a salt-water resistant double hardened and compressed aluminum casting,combining innovation with impeccable machine work. Modern production method sare utilized in conjunction with hand finishing, making each Seacam housing a work of art. The rugged housing has double O-ring seals on all control shafts for watertight integrity. A 3.5mm thick main O-ring sits in a precisely machined groove. The high-gradespring-mounted quick-clasps remain under full tension, unaffected by depth and pressure considerations.
    Seacam housings are designed to fit the palm of the hand, with controls falling naturally to the fingertips. Underwater the housing is slightly negative. So it will not float away, but it is light enough to avoid fatiguing the photographer. The ergonomic design of the individual operating elements is contrived so thathands rarely need to be removed from the grips, unless one-handed operation is preferred.
    The housing features LCD color monitor display, back display, visible and audible leak detector, 2 integrated and detachable hand grips, 2 Nikonos spring mounted flash bulkheads and 2 strobe arm base mounts for Seacam arms.
    Note! Lens port and viewfinders are required accessories
    Silver, Seacam's surface technology
    Silver, the surface technology of SEACAM, makes it possible to do without any varnish due to an entirely new surface refinement; The sea-water resistant aluminium precision-cast is doubly hardened and compressed; Additionally protected and sealed by hard eloxal, this surface withstands severest attacks by sea-waterand mechanical use
    Inside Coating
    Black flock material coats the inside of the housing; This reduces reflection and wicks away any water droplets that might enter the housing
    Zincs
    Two small plates are placed under each handle; These are sacrificial anodes; Any corrosion will attack here first instead of the housing
    Mechanical Controls
    The dependable controls are conveniently placed at fingertip, and kept water tight with Double O-Ring seal
    S-C-M Switch
    With a flip of a switch you could go from single servo, continuous auto focus and manual focus
    Standard Nikonos typeBulkheads
    External flash ready using Two Nikonos type sync cord connections
    Viewing
    Interchangeable viewfinders are available to fit your photographic style and subjects
    Multiple Lens Capability
    An assortment of interchangeable lens ports allow use of most macro, wide angle, and zoom lenses
    Construction
    Sea-water resistant aluminium precision-cast is doubly hardened and compressed without varnish; Additionally protected and sealed by hard eloxal, this surface withstands severest attacks by sea-water and mechanical use
    Control Type
    Mechanical
    Controls
    All
    Depth Rating
    265' (80m)
    Buoyancy
    Slightly negative depending on port
    Port
    Not included, required accessory
    Internal Flash Usable
    No
    External Strobe Connector
    Yes, Two Nikonos type
    2 flash arm base mounts for Seacam arms
    TTL Compatible
    No
    Moisture Alarm
    Yes
    Color
    Silver
    Dimensions (WxHxD)
    14.17 x 5.12 x 8.66" (360 x 130 x 220mm)
    Weight (without Camera)
    6.95lb (3.15kg)
    In this auction you will receive
    -Seacam 1ds/1d MKII Housing body
    -Body oring
    -Seamcam housing handles
    -Front port cover
    -Moisture alarm internal
    -1 tube of seacam o-ring grease.
  2. Is this still available? How much are you selling for?
    Thanks.
