Canon 7d setup
Started by maxoudendijkphotography ·
Canon 7d setup
  1. Hello,
    By using too little goes my almost unused ikelite set sale .
    This is a house for ikelite canon 7d with vaculoc chek , will you know if it is locked securely .
    Ikelite ports , 8inch dome and two dome ports for Canon 60mm and 100mm macro and 2 Customized reports .
    Ikelite DS125 flash with flash strobe arm and cable.
    2x PeliCase to store everything safely and neatly and much acecoire programs.
    The photos will follow.
    The set does not need road so no nonsense bids !
    set them together it took more than 5000
    Would you like to come and see it's of course possible.
    With best regards.
    Max Oudendijk
    Netherlands
