Marine grade double sided tape?
Started by Greatoldone ·
  1. Hi All,
    I need to re-attach a plastic mounting for my optical sync cord on my ikelite case. It originally came with a double sided, thin foam tape that held it on, but it's been knocked off, and the pad destroyed in the process.
    Can I use any old double sided tape, or is there a special marine grade that I should look for? I don't want it to be permanent either, as I'd like to be able to remove it later if I swap housings / camera etc.
    Jason
  2. 3M 4941 VHB Double-Sided Acrylic Foam Tape
    great stuff, works great, use it for many aquatic uses.
    Bill
  3. Thanks Bill. :)
