67mm adaptor from ebay
Started by punxzilla ·
  1. Has anyone used or have an opinion on these?
    Bubblescuba 67mm adaptor for ikelite.
  2. What housing are you using it with?
    There are a few 67mm adapters for various sized front ports....
    Personally I have used (as have many colleagues) the Ikelite 67mm adapter on Ikelite G series housings with the Inon UCL165 M67 with great results, especially as you can stack them (the lenses).
    The only SLR 67mm adapter I have tried is the subsea with a +10 Subsea lens, advantage of this is you can swing it out of the way underwater instead of having to unscrew it. The adapter and lens is expensive though.
  3. I am wanting to use it with an ikelite modular port for the 100mm canon 5510.35. I have used the inon 165 with my olD canon g10. I saw a bubblescuba lens adaptor on ebay for like 80. Has anyone used on of these?
