Sony E mount 16mm / Fisheye adaptor focus help / tips please
Started by DivingT ·
  1. Hello all,
    I am not new to underwater photo/video, but I am new to using a digital camera set up, and I'm looking for any advice on the camera focusing set up for a Sony NEX with the 16mm with the VLC-ECF1 fish eye adaptor lens, inside the Nauticam housing with dome port.
    When I used to film using a Sony PC5 miniDV camera in a Oceanhaus housing with 120deg wide angle port, I used to focus the camera to an object in the distance, leave the camera set to manual focus, and then once inside the housing with the wide angle port, everything from about 1ft / .3m to the distance was in focus.
    From my testing on land, this doesn't seem to be the case with the NEX camera. The autofocus works well, but I'm concerned in case the focus starts to come in and out when filming underwater, or even worse, focuses on port if I see something in the distance. I cannot find any focus gear for the 16mm lens. Is there some for the Nauticam housing
    Does anyone have any focus set up tips for this set up? Settings such as centre spot, multi spot, single shot or continuous autofocus etc, or has anyone found a good set up in manual mode? Will it work to focus manually ona distance object and get stuff in focus from 1m onwards?
    Any help would be great fully apretiated - I'm trying to fill gaps from old techniques to the digital world! LOL!
    Cheers Tony
    Edited by DivingT
