D800 with Nikon 24mm F1.4 GED Prime Lens
Started by RedKane ·
  1. Hello All,
    Does anyone have any experience, thoughts, comments, etc. with this combination? I am thinking of using it in my Subal housing with a 230mm dome with the appropriate port for a wide angle set-up. I have a Sigma 15mm FE lens already and am looking for another wide angle combination in place of using my 16-35 f4 setup. The 16-35 setup is positively buoyant whereas the 15mm is neutrally buoyant. Using the 24mm would reduce the luggage space needs and, hopefully, be closer to neutrally buoyant than the 16-35. I would lose the zoom capabilities of the 16-35 but I have no problems using my fins to "zoom" in and out. So, if the performance of the 24mm is as good or better than the 16-35, then it might be an option. So, I just wanted to explore this option.
    Thanks for any feedback.
    Karl
  2. That’s quite a compromise on focal length, just for a neutrally buoyant housing. If you want a prime lens, how about the 20mm f1.8?
  3. Hi Alex,
    I already have the 24 so the only expense would be the port for it. I know I am forfeiting some focal length for this and if I didn't already have the 24, I wouldn't even entertain this. I am primarily concerned on how well the 24 would perform in a 230mm dome, lightening my traveling kit, and a more neutrally buoyant set up. If it doesn't meet these criteria, I wll just pass and continue with my 16-35.
    (Now getting the photographer capable of using his setup as well as it can perform is an entirely different matter.)
    I saw in a previous post there was some discussion on a similar lens but it was in a smaller dome so I wanted to address this specifically.
    Karl
