Sea & Sea DX-G1 underwater Camera; Dual YS-01 Strobes and accessories
Started by jamiebk ·
  1. http://sfbay.craigslist.org/nby/pho/4935239803.html'> http://sfbay.craigslist.org/nby/pho/4935239803.html (Craigslist ad)
    I am shifting to video photography and am selling my Sea & Sea complete camera and dual strobe set with all accessories (total package).[/t-color][/font][/size]
    So.....I am selling this complete package for $1025.00 plus $35.00 if you would like this to be shipped[/t-color][/font][/size]
    What's in the box:
    (1) Sea & Sea DX-G1 digital 10MP camera and underwater housing
    (2) Sea & Sea YS-01 strobe lights with spotting lights and diffusers
    (2) Sea & Sea camera to strobe cables for TTL sync
    (1) Sea & Sea wide angle lens
    (1)Sea & Sea Close up 125 Lens
    (1) (set) of Sea & Sea "Sea Arm VII" mount and arm w/ extra arm for the second strobe
    (1) Lens caddy for wide angle lens
    (1) Sea & Sea Pelican brand padded hard case for all gear
    (3) Li-ion batteries
    (2) 4 GB memory cards
    (1) AC charger for batteries
    All original manuals for camera and strobes
    Extra O rings for camera and strobe housings
    (3) tubes Sea & Sea O ring lubricant (you must use their brand)
    All told, if you were to purchase these items separately they would total over $2500.00.[/t-color][/font][/size]
    • Camera $799
    • Strobes $700
    • Wide Angle $329
    • Close up $135
    • Mount and Arm Set $370
    • Case $150
    • Lens caddy $50[/t-color][/font][/size]
    "Other stuff" $???
    This camera kit has been with me on multiple dive trips and takes great pictures. An excellent set for an amateur or someone wanting to step up their photography to the next level...you all probably know Sea & Sea but you can check out the specs on the camera on the Sea & Sea webpage:
    http://www.seaandsea.jp/dx1g/'> http://www.seaandsea.jp/dx1g/
    The twin YS-01 strobes feature the following (from Sea & Sea website):[/t-color][/font][/size]
    • Circular beam angle of 100°x100° and guide number of up to 20. The YS-01 is a new compact-type slave strobe that can be used for all applications from wide-angle to macro photography.
    You can switch between DS-TTL (Digital Slave TTL) and a ten-level manual control function, to enable fine adjustment of the light level according to the photographer's intentions. You can also set up a lighting system that uses two strobes in DS-TTL mode. Power comes from four AA batteries for a powerful and long-lasting strobe. You can enjoy taking pictures all day long without having to recharge the batteries. The recycle time takes about two seconds with nickel-metal hydride batteries (2700 mAh) for stress-free continuous shooting. The YS-01 is furnished with a high-luminance white LED target light (1W) indicating the optical axis of the strobe attached to its front face that is effective for night diving.
    You can fully exercise your creativity with the YS-01, which can be used as a primary strobe or secondary strobe
    • Guide Number (ISO 100/m) (land)] 20
    Beam Angle] 100°x 100° (with diffuser 110°x110°)
    Batteries] 4xAA A: 6V Ni-MH: 4.8V
    Number of Flashes] A: 230 Ni-MH: 330
    Recycle time (full)] A: 2.5 sec. Ni-MH: 1.9 sec.
    Color temperature] 5600K
    Color temperature w/diffuser] 5250K
    Depth rating] 75m / 250ft
    Dimensions (WxHxD)] 68x108x129mm / 2.7x4.3x5.2inch
    Weight] : 450g / 15.8oz (w/o batteries) * Attached a fixing bolt to the Strobe.
    Underwater weight] : Approx.+10g / -0.4oz(w/ batteries)
    Others]
    - Exposure control: DS-TTL, Light level control dial (GN): 1 / 1.4 / 2 / 2.8 / 4 / 5.6 / 8 / 11 / 16 / 20 (10 steps)
    - Pre-flash control: Equipped with pre-flash cancel mode
    - DS-TTL function
    - Slave function
    - Auto power OFF function
    - Sync cord: Fiber-Optic Cable
    - Over-pressure relief valve
    - LED target light n a wide range of applications, from compact digital cameras to digital SLR cameras.
    This equipment is in excellent condition and all functions well. It has been carefully cared for and maintained...it has never flooded or required repair etc.
    Thanks for looking!
    Edited by jamiebk
  2. x
  3. bump
