Nauticam vacuum error
Started by smk82 ·
  1. Battery died on my vacuum sensor so replaced it, however it wont work right. With switch in off position, the led is flashing red. When its on, its solid red and sometimes gives audio warning.. no blue light or anything. Ive never had a leak or anything however...worked fine previously any ideas?
  2. Ask Nauticam.
  3. Try disconnecting the battery and reconnect (and be careful on how to put the battery in). Solid red supposedly means a leak, are the prongs of the leak detector side touching or touching the metal?
    Bill
  4. Tried all of this and no joy. Have spoken with nauticam and will be sending back to them
  5. Sounds like your replacement battery is weak or dead as well. Did you try another battery?
