HDMI Bulkhead GH4/Nauticam
Started by BenBrettingen ·
  1. I'm new to the whole underwater housing scene and I've got a unique situation which I need to figure out! I'm wondering what parts I will need to connect my GH4 through the m16 bulkhead via HDMI. The interesting part is I will be mounting the camera underwater and have my HDMI monitor above the water attached to a boat.
    Will these parts get me where I need to be? If not could you possibly suggest the correct setup.
    Nauticam HDMI (D-D) Extension Cable 5m / 16 Feet With HDMI Bulkhead
    Nauticam HDMI (D-D) Cable in 200mm Length for NA-RX100V (for connection from HDMI bulkhead to camera)
    Thanks for the help, it's really appreciated!
  2. Howdy,
    Yep, the parts you specified will work as you think.
    However I would definitely re-consider looking at your required length. I doubt you would get it over the side of the boat before running out of cable.
    You might have to speak with Nauticam to get a custom cable made up (depth x 3 as a starting point), I know Dive&See do a 30m HDMI cable (but is the wrong bulkhead)
  3. Thanks for the response. Up here in Minnesota we generally run "different" boats for fishing...they only draft about a foot of water and the gunnels are often less than a foot tall!
    Here is what I ended up going with and it works great. I'm thinking I might run into some signal strength issues but haven't thus far.
    I went with the Nauticam (A-D) cable 16 ft. with the Nauticam Standard HDMI bulkhead and a simple (d-d) 200mm cable.
    Easy as that!
    Edited by BenBrettingen
