Ikelite built-in TTL circuitry + sony A6000 >>> what shutter speed limit should I expect ?
Started by Eitan Ben Tsvi ·
  1. Sony A6000 - shutter speed limit with slow / built in flash = is 1/160
    Ikelite has a "bulkhead connector with built-in TTL circuitry" total solution
    - to electric flash triggering
    http://www.ikelite.com/housings/sony/6910.60-sony-a6000.html
    My question is what shutter speed limit should I expect ? in this way
    above the 1/160
    THX
    Edited by yaronad
  2. Probably the same as the onboard flash. Max sync speed is depending on the shutter, it is a per camera spec.
  3. Probably the same as the onboard flash. Max sync speed is depending on the shutter, it is a per camera spec.
    But there is no problem with Hss External Flash....I can go up to 1/4000
    My question is in this specific case of the TTL circuitry....
    what do you think = will be the upper shutter speed limit I can set in case
  4. OK I understand
    THX
