Help
Started by paul.hunter ·
Help
  1. Help
    What would be the best way to clean up the image on the right hand side? Any other idea's would be good.
  2. What exactly are you looking for? The image doesn't look dirty on the right side to me.
  3. Hi James
    It's that silver fish on the right that did not play along with the others that causes a distraction to me, what do you think?
  4. I don't find that "silver" fish too distracting but if it bothers you just remove it using Photoshop tools. Should be pretty easy to do. :)
  5. Use a combination of the cloning and healing brushes to remove it (just like backscatter). I would probably remove a few more of them will I was at it.
  6. Sweet :):D
    Karl
  7. Nice job Craig!! Even when using the healing brush to blend, sometimes you can tell that the image was edited; but your example is VERY GOOD at not abusing the tools and not leaving any impression that the image was "cleaned". 8) 8)
    Ponsui.
  8. Thanx guys that has helped alot.
    Paul
