problem with 5060 keypad
I'm shooting an Olympus 5060 in the PT housing with a Sea & Sea Auto DX90 strobe with the fiber-optic connector. The camera worked beautifully for a land-based vacation, but the last few times I went to use it - with no explainable cause - it began malfunctioning (on land and underwater).
Sometimes the camera takes pictures & zooms fine, but the arrow pad and OK/Menu buttons do not respond. Also, the Mode and Control dials will not work occasionally. At other times, the camera displays a rotatable option (like the focus selection mode), as if I was continually pressing the button when I was not. In playback mode, it will start cycling through all of the images as if I’m pressing a forward/back key when nothing is pressed, and will also randomly lock protect images when I did not touch the protect key.
Has anyone else experienced this problem before? Its obviously very frustrating to get the perfect shot all set up, then not be able to change shutter speed or switch "my modes" during the dive. The only solution I could find was to continually power the camera on and off.
Any info would be appreciated!
PS: Incidentally, when the camera cooperated, it did excellent. I found the best way to tweak exposure was to change shutter speed, rather the fiddle with the Sea & Sea f-stop adjustment.
