Silcion Lube for Nauticam o-Rings?
Started by Subarch ·
  1. I've been trying to get a straight answer regarding the proper silicon lube to use on my Nauticam housing's o-rings (gray). I was told that the Sea & Sea silicon (yellow tube w/blue cap) is fine but there is another type of Sea & Sea silicon that will damage the Nauticam o-rings.
    Also, is there a silicone lube out there that really can be used with both the Nauticam o-rings and the blue o-rings on the Sea & Sea YS D-1?
    Subarch
  2. Tribolube 71 and Christolube are both fine for ALL types of o-rings.
    Other wise you might think you need to carry 11 types of grease for all the o-rings you have
    Bill
  3. Thank you all for the info!
    Subarch
