For Sale: Ikelite Underwater Camera System - 5D Mark II. Dual DS-161+++
Started by Torleif ·
  1. Ikelite Underwater Camera System
    MRSP Total - 5 470 USD
    Auction starts at only 2 900 USD - ebay
    http://www.ebay.com/itm/251991602939
    (Camera & Lens is not included)
    Underwater TTL Housing for Canon EOS 5D Mark II
    The Ikelite DSLR housing is a seamless blend of functionality, lighting integration, durability and waterproof integrity.
    The True TTL Advantage
    Other housings simply waterproof your camera. An Ikelite TTL housing improves your photos. TTL or "Through-The-Lens" flash metering means the camera controls flash duration to properly expose an image. Our built-in proprietary circuitry tells your camera that a TTL external flash is attached, allowing the camera to adjust exposure more accurately than with slave TTL strobes.
    Fiber optic slave flash units require the camera's flash to fire every time. This creates a shutter lag as you wait for the camera's flash to recycle in between shots, drains your camera's battery life, and builds up heat inside of the housing. Ikelite electronics translate direct electrical impulses from your camera, triggering your strobe and precisely adjusting its power without the need to fire the camera's flash. This eliminates the slave TTL strobe issues of signal interference, inconsistent exposure due to weak fiber optic transmission and false triggering caused by light rays bouncing off the water's surface or your buddy's flash going off.
    Exposure Adjustment
    Exposure adjustments directly through the back of the housing put the perfect shot within reach every time. Tweak your TTL exposure or take total manual control without taking your hand off of your housing. Controls on the back of the housing acts as a remote control for compatible Ikelite DS-series strobes. Access plus/minus exposure compensation in TTL mode, plus manual power settings in half-stop increments.
    Ergonomics
    An over-sized knob smoothly engages our unique system of universal zoom gears. We provide two zoom sets with each housing, one for use with most popular larger diameter zoom lenses and a second designed for use with smaller diameter zoom lenses. Both sets are lightweight and easy to install with no modification to the lens required. A variety of dome and flat ports attach with four locking latches for maximum security and quick changes between dives.
    This housing includes a balanced aluminum tray with our signature quick release handles for easy attachment and removal of external lighting. An aluminum 1/4-20 threaded top mount provides an additional attachment point for lightweight accessories.
    Construction
    Special polycarbonate blends allow us to create an extremely strong yet clear and lightweight enclosure. We believe there's no substitute for inspecting the actual o-ring seal once your housing is closed. Our signature clear construction lets you see that the housing is watertight and dry before you enter the water, and provides full view of the camera while you're diving. Polycarbonate is fundamentally corrosion-resistant for easy maintenance year after year.
    Like every Ikelite product, our housings are designed, built, and tested in the USA. We use locally sourced, top-grade materials. Our housings are built by hand and individually tested for fit, function and waterproof integrity. The average assembly technician is a certified scuba diver and has over 16 years of experience building Ikelite products. We back our products with over 50 years of experience and the most accessible and responsive customer service staff in the dive industry.
    This housing requires the addition of a compatible lens port for waterproof operation. Lens port not included.
    DS-161 TTL Strobe with Video Light x 2
    The DS161 combines power with wide angle coverage to give you the most bang for your buck. The quality of light is exceptional due to a round flash tube and custom powder coated reflector designed specifically to deliver the softest, most even coverage possible. When combined with a compatible Ikelite TTL system or film TTL system, the DS161 automatically adjusts brightness to provide perfect exposure whether you're shooting macro, portrait or wide angle.
    Instead of a simple focus light, the DS161 includes a super even, 500 lumen video light. The light is suitable for close-up, macro, portrait, and wide angle fill-in work or as a focus assist light. Output is adjustable in 10 brightness settings plus an SOS mode for emergency situations. Automatic shut-off when the flash fires ensures that the video light will have no undesired effects on still photos.
    NiMH Battery Pack x 2
    They're not just better for the environment, rechargeable NiMH battery packs provide more power and quicker recycle times than AA cells.
    Ikelite Smart Charger
    Auto-ranging input allows the charger to work in any country whose electrical system falls within a 100V - 240V range. AC adapters for the following regions are included: USA, Europe, United Kingdom, and Australia.
    The charger showcases the latest pulse charge technology; this feature grants near complete charging while also conditioning cells over time, resulting in longer battery life and more flashes per charge. Its "trickle" charge mode helps maintain a pack's charge without danger of overheating. In addition, this charger is less likely to fail when used with poorly regulated power sources.
    Smart Charger is configured to charge a variety of 6-cell NiCad and NiMH Ikelite battery packs quickly and efficiently.
    Description MSRP
    Ikelite Underwater Housing for Canon EOS 5D Mark II DSLR 1800
    Ikelite DS161 TTL Strobe with Video Light 800
    Battery charger 100
    Ikelite-to-Ikelite TTL Dual Sync Cord 160
    Wide Angle Ball Arm Mark II for DS161 285
    Modular 8-inch Kit with 4.25-inch Lens Extension 575
    8 in. Dome with Shade (5510.45) & 4.25-inch Lens Extension (5510.24)
    Canon 24-70mm f/4L EF IS USM / Canon 17-40mm f/4L EF USM / Nikon 18-70mm
    8-Inch Dome Neonprene Cover 30
    Lens Extension - Modular 4.125-inch 175
    Canon 14mm EF f/2.8L II USM / Nikon 12-24 / Canon 10-22
    Leak Sensor / Detector 60
    Total: 5470 USD
    Edited by Torleif
  2. Price reduced - only 2500 usd for the complete system!!!
    Accept only PayPal payment.
    Free shipping.
    I have used this system with the Canon 16-35 f/2.8 II lens. It works well, but you need to be gentle with the zoom knob.
    I will attach the procedure to install the lens and zoom gear.
    I have used this system with a Canon 14mm f/2.8 II lens and the 16-35 f/2.8 II lens.
    I also have a mint Canon 5D Mark II camera body for sale.
    If the system is not sold within 2 weeks, everything will be split into parts and sold on ebay.
    Please contact me on torleif.lie@mac.com for more information.
  3. Will you sell just the strobes?
  4. Will you sell just the strobes?
    PM sent
    Please see www.AeroCam.no and the blog for some UW photographs with this set-up.
  5. Hi, do you still have the housing and if so would you be willing to ship to the UK? And then if so how much for just the case only or with the ports?
    Thanks, Simon.
