FS (2) Inon Z-240 Strobes
Started by waterloggedimages ·
  1. Up for sale is 2 Inon Z-240 strobes in excellent condition. They do not have a lot of dives on them, no scratches, dings, never flooded. Comes with original boxes and paperwork. I would like to sell them as a pair. The only reason I'm selling them is because I'm doing more video and they aren't being used. They work perfectly. $600 Each. Buyer pays all shipping and Paypal fees. Accept Paypal only.
    Features:
    • High power with Guide Number 24, wide 100 degrees circular beam angle
    • light distribution even without a diffuser
      • INON unique T-shape Twin Flash construction and optimally designed reflecting mirror/prism enable effective light distribution and produce powerful guide number 24 (*1) at wide circular 100° beam coverage without a diffuser from compact body (outer diameter:99mm x depth: 100mm x height: 122mm) (*2) run by only 4 x AA batteries. Even for shooting wide subject, the Z-240 delivers strong strobe light to an entire area without using a diffuser which suppresses strobe power. Packaged -0.5 White Diffuser 2 (TTL/Manual) increases bean angle to 110 degree (guide number 21). With the white diffuser, color temperature of the Z-240 decreases at 100K (Kelvin) only to depict underwater scenery in same color regardless of using the diffuser or not.
        • (*1) Measurement in air/ ISO100m, Nominal value
        • (*2) Excluding protruded parts.
    • Minimum recycle time 1.6 seconds
      • Minimum recycle time at full flash (how fast the strobe is ready to fire just after full flash) is approx. 1.6 sec.(*3). The Z-240 unique circuit components carries two sets of fundamental electrical parts (transformer and transistor) to achieve fast recycle time.
        • (*3) With SANYO Twiicell 2700 Series, HR-3UTG, 1.2V, Min.2,500mAh.
        • Recycle time/flash capacity based on INON test data. Actual values may vary depending on battery manufacturer, battery type etc. and age.
    • Optical connection/electrical connection, digital/film fully compatible
      • The Z-240 offers all advanced features including S-TTL Auto mode which supports TTL Auto exposure control by transmitting built-in flash light to an external strobe and compatibility with Clear Photo System. Optical connection system widely supports from transparent housing for compact digital cameras to a housing for digital SLRs with built-in flash regardless of make or model. Its sync connector accepts Nikonos 5 pin type cable to shoot in TTL Auto mode with a film camera or in Manual/External Auto mode with high end digital SLR not equipped with the built-in flash (*4).
        • (*4) Usable function may vary depending on camera system and connection method
    • EV. Controller to adjust exposure of S-TTL Auto
      • It is simple to fine-tune flash power in S-TTL Auto by dialing the EV Control Switch on the back control panel. Adjustable range is 3 steps to increase and 6 steps to decrease, to suit to personal preference or different exposure control characteristics among camera models.
    • Next generation wireless TTL
      • The Z-240 Type 4 successfully amplifies receiving optical signal from the slave sensor 20 times more comparing to previous Z-240 Type 3 to provide wireless S-TTL Auto mode using a mirror instead of an optical cable. Attaching optional Wireless Connection Kit on the Z-240 Type 4 and combined with a housing via Shoe Base Set or Grip Base D4 Set creates a handy S-TTL Auto shooting set.
    • 13 step Manual / 24 step External Auto
      • The Z-240 supports professional needs for sophisticated and precise lighting by its 13 step Manual mode with 1/2EV. increments and by semi-automatic 24 step External Auto mode with 1/4EV. increments which determines strobe output based on onboard sensor. INON unique Advanced Cancel Circuit benefits you with faster recycle time and more images per battery set to eliminate drawbacks when using with a pre-flash type digital camera where the built-in flash always burst full dump.
    • High-intensity 180 lumen power LED
      • Focus Light with shutter linked auto OFF function
      • Multifunctional Focus Light for supporting focusing as well as for using as an indicator of strobe charge status since it turns on in synch with strobe's ready LED lamp. The Z-240 Type 4 uses high-intensity 180 lumen power LED as Focus Light which is also usable as an independent diving light producing 180 lumen/20° coverage. The Focus Light automatically turns OFF in synch with shutter release where it quenches emitting light at the time of pre-flash under Optical D Cable Connection with a pre-flash type digital camera, so it is never recorded in an image (*5).
        • (*5)Focus Light may be recorded on an image depending on camera system, connection method and shooting condition.
    • Integral pre-flash mode detecting function
      • Fully compatible with a camera like Nikon digital SLR cameras D700/D300/D200/D90/D80 which alter number of pre-flash between once or twice depending on shooting condition making total flashes twice to three times. The Z-240 automatically identifies number of pre-flash to activate adequate program to support proper functioning of External Auto, Manual as well as precise S-TTL Auto mode.
    • Manual + TTL Auto mode for film cameras
      • Newly introduced flash mode for hard wired film camera to pre-set maximum flash power in TTL Auto exposure to compensate the weakness of the TTL Auto mode. Conventional TTL Auto may not get along with a particular situation like shooting a swimming fish without colorful back ground where TTL Auto could deliver full damp resulting from TTL error. The Manual + TTL Auto mode can avoid this problem by manually setting necessary flash output for a subject to stop firing at pre-set flash amount in case of TTL error happens and benefit you to drastically reduce overexposed images.
    Edited by waterloggedimages
  2. r these still for sale cheers
  3. yes
  4. sold
