Canon g16 settings
Started by Sashok ·
Canon g16 settings
  1. Hi all
    I am new in photography and just bought canon g16 in fantesia housing
    I am looking for tips and trick and setting advise mostly for warm waters such as red sea
    Thank you all
  2. Take a look here: http://www.uwphotographyguide.com/canon-s90-g11-underwater-settingsThat is mostly what I did with the G15.
    I set up C1 for macro (including the lens zoom that gave the best magnification with some reasonable working distance, 13 cm or so as I recall). I setup up C2 for action wide-angle. 1/125s, fast f/stop, widest zoom setting, and auto-ISO
    Do you have an external strobe? That would definitely change what you use for Macro.
  3. I just returned from Marsa Alam (Red Sea, Egypt) and had my first session with my Canon G16 in the Fantasea housing, wide angle lens and 2 x INON D2000 strobes.
    My standard setting was:
    ISO 80
    f/5.6
    1/125
    During the dive I mostly adjust the aperture.
    I like the background with the shutterspeed at 1/125.
    In a cave you will need to increase the ISO.
    I am new at UW photography and made around 20 dives with a camera so far.
    But I happy with the results so far.
  4. Hi
    Wow pictures are nice
    Did you use any light or strobe?
    And what about white balance?
  5. I have 2 INON strobes (1x S2000 and 1x D2000) which I used at maximum output.
    White balance is on automatic and just very small adjustments in Photoshop are needed afterwards.
    (For each picture I increased the color red as I did not have a red filter)
