Sony NEX6 shutter speed and strobes
Started by morten.christiansen.96 ·
  1. Hi,
    I have been shooting with a Sony Nex6 in a Nauticam housing and with YS-D1 strobes for a few years now.
    The camera onboard flash triggers the strobes via FO cable. When the onboard strobe is switched on the camera limits the shutter speed to 1/160.
    Has any of the forum participants an idea about how to get faster shutter speed with the onboard flash switched on? Or is there a solution somewhere which allows for bypassing the onboard flash and still triggering the strobes?
    Morten
  2. Pretty much the only way is to use a Nikonos adapter and the hotshoe. I tried to get a flash trigger built, but there is not enough space in the Nauticam housing.
  3. Thanks for the advise. Can you recommend a shop where I can purchase these items?
    Br,
    Morten
  4. Hi,
    I saw this on the Internet: http://www.bluewaterphotostore.com/blog/photo/a6000-sync-cable-vs-fiber-optic/
    I asked the publisher if this would also allows for faster shutter speeds than 1/160 when using the sync cords and hot shoe adaptor. So far no answer.
    Can anybody advice if the shown setup will allow for faster shutter speeds than the max. 1/160 when the internal camera flash is on?
    Morten
