gh4 sound issue
Started by lutfu ·
  • 18Posts
  • 18Replies
gh4 sound issue
  1. hello
    this is my first filming with gh4 ,i filmed this last week but when i turned back home i noticed that a strange sound is coming from my recordings...
    since the camera is not with me.i can not test if it makes the same sound .
    does anybody else had this issue?
    i will get the camera back a week later..
    https://vimeo.com/139876448
  2. Sounds like a boat engine!
  3. What lens? Sounds like AF motor for me.
  4. i wish it was the boat engine but on the lake there were only cyclıng dolphins, :(
    the lens was a 7 14 brand new but the version was 1.1 (İ dont know if there is a newer update for the lens) also when i used the camera 3 weeks ago i filmed with an olympus 14 42, i will try to find those files and try to listen if the same sound is coming
  5. Can it be the housing? But how? This is with olympus 14 42
    https://vimeo.com/139951945
    and this one out the housing
  6. Sounds like a resonance inside the housing. Noticed that frequency noise is higher with the 14-42 than the 7-14 lens.
    Maybe you have a bad contact between the lens and GH4 so focus motor always chasing as Escape mentioned.
    Might be a GH4 defect, could you test the same lenses with another GH4?
    Sent from my iPad using Tapatalk
  7. Hello, i couldnt wait and told friends to send me the camera and it is with me now......
    I think it makes the sound out of the housing as well .
    I think escape is right , it looks like a focus motor sound, when i put the camera to manual focus i didnt hear the sound
    But why a camera records the focus motor sound! ? What can be wrong with it,
    https://vimeo.com/140033947
    I think iespace is right , it looks like a focus motor sound, when i put the camera to manual focus i didnt hear the sound
    Edited by lutfu
  8. The noise from the lens is transiting though all contact points between the focus motor to the internal mic. This is normal. Your lenses might be noisier than usual or your internal mic more sensitive than normal.
    Try to reduce the mic input level, I must check on my GH4 what others parameters we can play with.
    With some lens the zoom motor can be noisy too.
    Many will use an external mic (of course not for underwater), isolated for vibration from the camera body.
  9. Thanks for the information guys
    the last movie(the carpet one) was with an olympus 14 42 ,i will get my lenses 7 14 and olympus 12 50 a week later, i will make tryings with them and share the results here
    thanks again
  10. https://vimeo.com/141811502
    yes the focus is locked but the noise is still there
    anybody having the same issue like that
    thanks
  11. Video 'Continuous AF' turned on within the menu?
  12. Video 'Continuous AF' turned on within the menu?
    Sent from my iPhone using Tapat
    Yes it is on
    Edited by lutfu
  13.
    Yes it is on
    Turn it off - See if it makes a difference. Movie Mode ignores the AF switch on the back of the camera
  14.
    thanks a lot , i will try this tomorrow since i dont have the camera with me now...
    i hope it works
  15. yes it worked. when i turned off the continuous af, the sound cut off
    Thanks thetricster for the help
    But dont we need that feature when we are filming? And guys with gh4 out there when you turn this feature on, do your cameras make this funy sound
    Thanks and regards
    Lutfu
  16. yes it worked. when i turned off the continuous af, the sound cut off
    Thanks and regards
    Lutfu
    I've never used continuous af underwater. I found with the GH4, manual focus and using the back button AF/AE losk set to lock AF a better option.
  17. yes it worked. when i turned off the continuous af, the sound cut off
    Thanks and regards
    Lutfu
    Mine is turned on. It usually sucks for recording because of the hunting, but I often like to use it to get focus during the first few seconds of a shot, then lock the focus off by turning the lever to manual focus. I would say 30% of the time I do that. 70% of the time I'm in MF when I start the shot.
    I've never noticed that funny sound. I don't think I have it.
  18. I would 't use ANY continuous AF system unless it had phase detection.
    These Mirrorless cameras (and most compacts) use Contrast Detection, which causes the 'in focus, out focus, back in focus' issues when its hunting - and gives you have odd looking footage.
    Personally I have the AF switch set to 'S-AF', Continuous-AF turned off and have Shutter-AF turned on. Then when I want to record I point the camera at either the subject (or something 2-3m away)- with the hyper-focal distance providing everything in focus (for f5.6) at that distance and beyond.
    If I need to refocus while recording, you can either half-press the shutter or you can configure the AF/AE on the back to perform focus.
