Lens correction filters for cold/green water, kindly ask for help
Started by bigmaras ·
  1. Hi,
    I'm owner canon 50d + canon 17-85 lense to uderwater photo I have Ikelite house 6870.50 + dome port 5503.90. I'm diving usually in cold green water in Poland and I have question about correction filters:
    What model, brand filter should I buy? Dedicated Ikelite or maybe other brands are better?
  2. Hi bigmaras
    Take a look at Magic Filters http://www.magic-filters.com
    Reasonably inexpensive as uw equipment goes and can be used without a strobe.
  3. Hi bigmaras
    They have "GreenWater Magic filter" for diving in cold/green waters but I don't see canon 17-85 in the compatibility table, so probably my lense is incompatible :]
  4. I believe the filter thread for the 17-85 is 67mm. Just get the next size up (77mm) and trim it size with some scissors.
  5. I believe the filter thread for the 17-85 is 67mm. Just get the next size up (77mm) and trim it size with some scissors.
    Bigger size and cut by scissors, is it joke?
    BTW. I ordered Kenko 67 flw.
  6. No, we're not kidding!
    They're made of a gel-type material and you can cut them to any size. So if you need 67mm - or whatever - and that size is not available, you can order a bugger size, cut them and then mount in a, say 67mm filter UV filter.
    It may sound a bit weird, but, believe us, it works no problem. It's, as I said, an easy and relatively inexpensive solution.
  7. I've used the Green Water Magic filter a lot and they work incredibly well.
    Two points:
    1. You need to manually white balance with them. If your subject changes depth by more than 2m or so, you need to re-white balance.
    2. You need to shoot at a slight downward angle. If you get to much ambient light from the surface, this produces a color cast.
    In terms of mounting, I tend to get a small piece of the filter and stick it onto the rear end of the lens with some tape as they demonstrate with the Tokina 10-17mm here: http://www.magic-filters.com/tokina.html
    In cold green water, with this filter, you can actually extract more detail from a scene than your eyes can make out....
    Adam
