Ikelite Canon 10D housing...question for Ike
Started by divedoc ·
  1. Ikelite Canon 10D housing...question for Ike
    In a previous post from Ike:
    "We received actual housings for the Canon 10D and have started nailing them together which will take several weeks to get from drilling holes to water pressure testing. Will introduce eTTL when available. Retrofit may require return home if we elect to machine a pocket into the back as we do on the Olympus housings. "
    Ike,
    Will the 10D and D60 housings be compatible with both cameras? I have both cameras but my Sea and Sea D60 housing will not quite work (it almost works) with my 10D and I have heard on here that the UKD60 housing kind of works with both. It would be most excellent if the 10D housing worked on the D60 as well.
  2. You can use the Sea and Sea D60 housing with a 10D if all you want is to actuate the shutter and the command dials.
    BVA
  3. You can use the Sea and Sea D60 housing with a 10D if all you want is to actuate the shutter and the command dials.
    BVA
    BVA,
    Just tried the 10D with the Sea and Sea housing. Shutter, F-stop and shutter speed all work although the menu buttons are a little off.
    I had a major leak in Indonesia last month killing my D60 and 100 mm macro. I got a new D60 on Ebay and used it last week in Bonaire with the same housing that still leaks a little after a complete O-ring change. I like Ikelites visible O-rings and tough housing design and wonder if the Ikelite design handles functions of both cameras better.
    Thanks for the info.
  4. Ikelite does not have a D60 so have no idea. We probably would have forgotten the D60 because of its age, but can offer if people want............
  5. Ikelite does not have a D60 so have no idea. We probably would have forgotten the D60 because of its age, but can offer if people want............
    Thanks Ike...
    Hmm the D60 appears to becoming an antique. The 10D menu functions and the D60's are very close with a few minor exceptions. I guess I'll buy the 10D housing for the 10D and see if the ancient D60 fits as well.
