FS: Full RX100 kit (housing, strobes, arms, wet lenses)
Started by Jensm ·
  • 11Posts
  • 11Replies
  1. Hi,
    As the next dive trip is in some distant future, I'm letting this go. Selling it all as a kit. Most of it has only been used for two diving holidays, the strobes and a few bits I bought second hand.
    Located in Denmark. As for price, give me a realistic offer.
    1 Sony RX 100
    1 Extra battery, higher capacity for RX100
    1 Patima PDCH RX100 housing,
    1 INON Wide angle lens UWL-100 M67 Typ II,
    1 INON Macro lens UCL-165 M67,
    1 Nauticam single handle tray with 2pcs 1/4" screws,
    2 Strobe mounting ball for Easitray & Flexitray,
    1 Nauticam extra handle
    2 Nauticam 200mm Double Ball Arm,
    1 Nauticam double Lens Holder M67,
    4 H2O--Tools Clamp for double ball strobe arms,
    2 INON S2000 blitz,
    2 INON Optisk kabel,
    2 Adapter til Inon blitz,
    1 Peli Case 1400 with foam (480141)
    Edited by Jensm
  2. Hello there, $1200.00 plus shipping to Saba, Dutch caribbean, Netherlands Antilles.
    Michael.
  3. Out of interest do you get vignetting at 28mm with that lens?
  4. hello, im very much interested in the lenses, if you would consider selling them seperately, are they in good condition? no scratches etc?
    cheers,
    nick
  5. also interested in the lens holder....
  6. also, @ interceptor121, im not much on the technical details but i have been using this lens - uwl 100 - (borrowed from a friend) with my rx100 ii in a recsea house with no vignetting at all...
    by the way thanks for your articles on this topic on your blog. was very helpful to me when i was choosing the lens for my system. i ended up buying a second hand uwl 04 which was ok but gave me very soft corners so i routinely ended up zooming in a lot and loosing much of the 'width'
    the only problem i encountered with the uwl 100 was what i believe is called 'chromatic aberation' (?). sometimes when i am editing the images i start to see little rainbow artifacts around the outer areas of the image. i will try to find an example and post it. still this lens is the best one i have treid for the rx100 ii system i have.
    cheers
  7. Do you have the achromatic version with the marking on it?
  8. i honestly have no idea.. it was borrowed from a friend and is now in indonesia while i am in malta.... please advise regarding this achromatic version with markings... would be very helpful to know as i am currently shopping for a new one....
    thanks
  9. Or is lens flare from the sun reflecting... I think adding a shade to the h100 will solve it.
  10. The UWL-H100 has a hood but he is talking about the older UWL-100 that hasn't. Flare or ghosting happen for sun reflection though. Chromatic aberrations around contours are due to lens issues. The Sony is not as good at correcting I have use the same wet lens with a Panasonic micro four third and the image is clean with Sony it has blue fringing
    Edited by Interceptor121
  11. hi is this gear sold or do you still have the lens for sale?
    cheers, nick
