Small HD Nauticam Heat sink issues
Started by Illion ·
  1. hi Team
    i was wondering if anyone else was having issues with the small HD monitor.
    functionally its fantastic and has really improved the quality of the shots i am getting, but after 45mins or so of diving the monitor is ridiculously hot.
    does anyone have any tips on fixing this? or know if I'm doing something wrong?
    any help would be really appreciated.
    thanks in advance
    troy
  2. You can try to use Green Heat Conductive Rubber. This material helps a lot, to transfer heat from the device to aluminum case of the monitor. I used successfully for my Atomos Ninja-2 monitor/recorder, before i change a design of the case.
    www.diveandsee.com
    Edited by combatalex
