Subtronic maxi & mini
Started by tamas970 ·
  1. Does anyone have experience/knows the Subtronic Maxi and Mini strobes? I see an opportunity to pick up a pair 2nd hand. Since they are older models, I cannot find too much info on them, especially specs of the maxi.
    How do they compare to the z240 in terms of:
    - total weight?
    - reliability?
    - service demand (life of the flash tube? It is different than the 5500K units of Inon)?
    - performance/GN under water?
    I would also be interested, if the units can be converted to use AA-batteries, the battery arm is a good idea,
    however a bit restrictive in case you want shorter arms.
    Also I see it uses an electrical connection, is it possible to interface it to optical? (TTL or non-TTL)
