Inon D-2000W Strobe with Sync Port and fiber optics S-TTL
Started by blibecap ·
  1. Used Inon D-2000W S-TTL Underwater Camera Strobe with Sync Port, Excellent condition with some minor cosmetic scratches. Works great! The Inon D-2000W has the same high performance of the D2000 model. In addition to the base specifications, The D2000W includes a 5 pin-type electrical connector port for compact digital and digital SLR cameras. Nikonos type 5 pin-connection - Manual + TTL mode - 24 step External Auto mode is compatible - 13 step Manual mode is compatible Fiber optic connector - S-TTL is compatible - 24 step External Auto mode is compatible - 13 step Manual mode is compatible - Able to switch between ALL useable flash modes underwater (with compatible cameras). High power with Guide Number 20, Wide 100° circular distribution even without a diffuser Patented T-shape Twin Flash structure produces guide number 20 with wide circular beam angle 100° even without a diffuser to deliver strobe light wide area. The beam coverage increases to 110° with a diffuser. This ideal circular strobe light distribution does not require locating the strobe parallel to camera to support sophisticated and flexible angled lighting with strobe arm. Precise S-TTL Auto mode works with any make The D-2000 offers highly accurate S-TTL Auto mode by transmitting built-in flash light to an external strobe regardless of make or model of camera. The S-TTL Auto does not require any complicated setting. You do not have to buy new strobe when you upgrade from point & shoot digital camera to digital SLR camera. Fine adjustment to match with your taste even in TTL shooting S-TTL Auto mode provides great usability beyond traditional TTL with its fine flash output adjustment simply by dialing the EV. Control Switch on the back control panel. Besides standard exposure setting, flash output can be adjusted at three steps to increase and five steps to decrease for more usability over conventional TTL. Built-in high-intensity Focus Light The Focus Light assists focusing in darker conditions without influence on an image by shutter-linked auto OFF feature Integral pre-flash mode detecting function The D-2000 automatically identifies the number of pre-flashes for proper functioning of External Auto, Manual as well as precise S-TTL Auto mode. Works with standard AA batteries, and standard rechargeable NiMH batteries. You will get the best performance using Eneloop Rechargeable Ni-MH, which also happen to be recommended by the manufacturer.
    I have both of the user manuals. The 5 pin-type electrical connector port on the back is the same as a Sea&Sea cable. As far as I know this has never been flooded and the battery contacts are very clean. post-2195-0-11080100-1449888239_thumb.jpgpost-2195-0-53014300-1449888254_thumb.jpgpost-2195-0-09936800-1449888264_thumb.jpgpost-2195-0-14128300-1449888297_thumb.jpgpost-2195-0-56847200-1449888372_thumb.jpgpost-2195-0-87405600-1449888387_thumb.jpg
    I am looking for $350 for this flash and will accept paypal payment plus shipping charges.
    My eBay:Summary blibecap (585)
    Please see attached pictures.
    Bill
    Edited by blibecap
  2. Now Accepting offers
  3. any offer
  4. PM sent
  5. SOLD Thanks
