Best diffusor for CFWA?
Started by Segerdahl ·
  • 10Posts
  • 10Replies
  1. Hey Segerdahl
    If you live somewhere where milk or yoghurt comes in white or creamy coloured plastic bottles/pots, I'd suggest cutting a couple of those up into shapes that best fit your strobes and using paracord to attach them. Cheap, easily replaceable, totally customisable - and, dare I say it, almost environmentally, recyclable friendly..... ... and a fun project! :crazy:
  2. Hey Segerdahl
    Hi Tim,
    Thanks, but I already have flat diffusors. That was not the issue. I have been taking uw-photos with diffusors for about 25 years... ;-)
    As you could see if you followed my links, I am talking about DOME like diffusors. Diffusors specially made for CFWA.
  3. Sure! You must have cut up a lot of milk bottles then, eh? :lol2:
    I had looked at the links but does a domed diffuser make that much difference even for CFWA?
    Edited by TimG
  4. I have the Glowdive diffusers. Love them. Very soft, very even light. Hot spots are almost gone entirely.
    They are well made. Certainly not an inexpensive solution, but nothing is with UW photography.
  5. I'm not sure that domed diffuser will really help with CFWA.
    The soft, diffused light that they produce is fantastic for lighting wide-angle scenes. When you are lighting a subject on the dome port, I am not sure that they will make a huge difference.
    Adam
  6. I have the Glowdive diffusers. Love them. Very soft, very even light. Hot spots are almost gone entirely.
    Thanks for the reply!
    Do they change the color of the light?
    How is the attachment?
    Good/bad?
    Just press it on or!?
    Adam
    The idea was that they would better light up subjects close to the dome with a more even and less strong light. Causing less backscatter (which always is a pain).
    Also when you shoot something close to a wall, it is hard to get an even light on the strobe close to the wall.
    Edited by Segerdahl
  7. Sure! You must have cut up a lot of milk bottles then, eh? :lol2:
    Nope, we get our milk in tetra pak. No plastic...
    Well I haven't tested any dome diffusors myself, so I don't know for sure.
    The sample images at Glowdive's link is all what I have seen and to me they look very promising.
    My main head ache is if I should go for Ikelite's or Glowdive's.
    They probable do a similar job, but there could be other reasons to pick one over the other such as built quality, material (will they break easily?), how they are attached (easy to remove under water, safely secured etc), how they alter the color of the light etc.
  8.
    Yes, but thanks for the tips.
    I can't see any strong reason of using them instead of the standard diffusor (that's included with the DS161 strobe) though. The difference seems to be too little.
    Edited by Segerdahl
