Ikelite Canon 60mm F2.8 fixed port + Close up filters
Started by MarcusMalta ·
  1. Hi,
    I have an Ikelite 60mm fixed post for Canon AFS 60mm F2.8. Will a +10 close up filter sit in the port or I have to use a wet lens magnification?
  2. I have the same setup should be plenty of room
  3. Great Loza. Thanks.
  4. Do you have any suggestions on what brand of diopters/close up filters should I use and in what magnification with a Canon 60mm F2.8?
  5. I have played around with the Hoya set and they seem fine.You can stack them and are cheaper then the Canon brand which I havnt tried yet
