MFT new system for Panasonic GH4
Started by Rugani ·
  1. My friend has bought a Panasonic GH4 and is now searching for the best underwater housing system.
    Which would that be?
    Nauticam?
    Subal? Subal has not really a great port choice for different lenses or does somebody have better informations (Olympus 60mm, Olympus 8mm 1,8, Olympus 12-50mm)
    Thanks in advance for good tips!
    Kind regards
    Armin
  2. Does the Subal unit come with an integrated vacuum sensor & zinc anodes? At recent Nauticam housings these belong to the standard setup. Otherwise true, Nauticam has great port availability, however, I would also consider using a flat port and a WWL-1 for wide, and a close-up for macro.
    For workmanship they are probably equally good.
    OTOH, Subal is made in Austria, your factory support is on your doorstep, which can be a great advantage:)
