Rx 100 mk3 with UWL-H100 28M67 Wide Conversion Lens
Started by CP1962 ·
  1. I know old question but i am thinking of buying this lens for my nauticam RX 100 mk3. But i would like to see some photos taken
    with the Sony RX 100 mk3 and this lens with out the dome. So if you have any please show me or refer me to your website.
    Thinking of UWL-H100 28M67 Wide Conversion Lens or Fantasea Big Eye. So please let me know the pro and cons
    of both?
    Was in the shop and put the Inon on but its a difficult decision to make for me on dry land?
    Thanks in advance :dancing::dancing:
  2. The UWL-H100 does not vignette at 24mm though it gives some fringing in the corners it is around 110 degrees wide
    The fantasea big eye is not a wet lens but a dome it only gives you back the land field of view of 84 degrees sufficient for video but not for stills
  3. Please share some photos taken with RX100 mk3 and the UWL-H100 28m67 with out the dome??? :clapping::clapping:
  4. I have the mark IV same lens but I only use it for video. The topic was discussed time ago here in wet pixel
